*mechanisms()
Creates a mechanism in HMASCII format.
*mechanisms (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the mechanism.
name
The name of the mechanism.
color
The color of the mechanism. Valid values are 1-64.
To create a mechanism with ID 100, name "my-entity", and color 1:
*mechanisms(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0.120
