*resultsubcases()
Creates resultsubcases in HMASCII format.
*resultsubcases (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the resultsubcase.
name
The name of the resultsubcase.
color
The color of the resultsubcase. Valid values are 1-64.
To create a resultsubcase with ID 100, name "my-entity", and color 1:
*resultsubcases(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
