*seamjunctions()
Creates a seamjunction in HMASCII format.
*seamjunctions (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the seamjunction.
name
The name of the seamjunction.
color
The color of the seamjunction. Valid values are 1-64.
To create a seamjunction with ID 100, name "my-entity", and color 1:
*seamjunctions(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
