*lists()
Creates a list in HMASCII format.
*lists (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the list.
name
The name of the list.
color
The color of the list. Valid values are 1-64.
To create a list with ID 100, name "my-entity", and color 1:
*lists(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
