*elementclusters()
Creates an elementcluster in HMASCII format.
*elementclusters (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the elementcluster.
name
The name of the elementcluster.
color
The color of the elementcluster. Valid values are 1-64.
To create an elementcluster with ID 100, name "my-entity", and color 1:
*elementclusters(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
