*alereferencesystemcurves()
Creates an alereferencesystemcurve in HMASCII format.
*alereferencesystemcurves (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the alereferencesystemcurve.
name
The name of the alereferencesystemcurve.
color
The color of the alereferencesystemcurve. Valid values are 1-64.
To create an alereferencesystemcurve with ID 100, name "my-entity", and color 1:
*alereferencesystemcurves(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
