*rigidwall()
Creates a rigid wall group in HMASCII format.
*rigidwall (id basex basey basez normalx normaly normalz)
HyperMesh HMASCII Command
id
The ID of the group that is a rigid wall.
basex, basey, basez
The x, y, z location of the base node.
normalx, normaly, normalz
The x, y, z components describing the unit normal vector.
None.
