*memberjoints()
Creates a memberjoint in HMASCII format.
*memberjoints (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the memberjoint.
name
The name of the memberjoint.
color
The color of the memberjoint. Valid values are 1-64.
To create a memberjoint with ID 100, name "my-entity", and color 1:
*memberjoints(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
