*contactsurfelement()
*contactsurfelement (elementid facecode reversecode)
HyperMesh HMASCII Command
elementid
The ID of the element whose face should be use.
facecode
The face identifier specifying which face of the element to use.
reversecode
0, if the direction matches the normal of the element. 1, if the direction opposes the normal of the element.
The *contactsurfelement() command applies to the contact surface that was most recently created using the *contactsurfs() command.
None.
