*solvermasses()
Creates a solvermass in HMASCII format.
*solvermasses (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the solvermass.
name
The name of the solvermass.
color
The color of the solvermass. Valid values are 1-64.
To create a solvermass with ID 100, name "my-entity", and color 1:
*solvermasses(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
