*assembly()
*assembly (id color name)
HyperMesh HMASCII Command
id
The ID of the assembly (must be unique).
color
The color of the assembly. Refer to the color variable chart.
name
The name of the assembly
Assemblies are collections of components. The components in an assembly must follow the assembly definition using the *assemblycomponent() command.
None.
