*perturbations()
Creates perturbations in HMASCII format.
*perturbations (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the perturbations.
name
The name of the perturbations.
color
The color of the perturbations. Valid values are 1-64.
To create perturbations with ID 100, name "my-entity", and color 1:
*perturbations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
