*velocity()
*velocity (id type locationid inputsystmeid comp1 comp2 comp3)
HyperMesh HMASCII Command
id
The ID of the element (must be unique).
type
The element type.
locationid
The node ID where the load is applied.
inputsystemid
The reference coordinate system of the load (must be a valid system or 0).
comp1
The x component of the load.
comp2
The y component of the load.
comp3
The z component of the load.
None.
