*force()
*force (id type locationid inputsystemid comp1 comp2 comp3)
HyperMesh HMASCII Command
type
The load type.
id
The ID of the load (must be unique).
locationid
The node where the load is applied (must be a valid node).
inputsystemid
The reference coordinate system of the load (must be a valid system or 0).
comp1
The x component of the load.
comp2
The y component of the load.
comp3
The z component of the load.
Force definitions must follow a *loadcollector() command.
None.
