*integrationrules()
Creates integrationrules in HMASCII format.
*integrationrules (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the integrationrules.
name
The name of the integrationrules.
color
The color of the integrationrules. Valid values are 1-64.
To create integrationrules with ID 100, name "my-entity", and color 1:
*integrationrules(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
