*solverrepresentations()
Creates a solverrepresentation in HMASCII format.
*solverrepresentations (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the solverrepresentation.
name
The name of the solverrepresentation.
color
The color of the solverrepresentation. Valid values are 1-64.
To create a solverrepresentation with ID 100, name "my-entity", and color 1:
*solverrepresentations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
