*sequences()
Creates a sequence in HMASCII format.
*sequences (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the sequence.
name
The name of the sequence.
color
The color of the sequence. Valid values are 1-64.
To create a sequence with ID 100, name "my-entity", and color 1:
*sequences(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020.1
