*pressure()
*pressure (id type locationid inputsystemid face magnitude pressuretype vectorx vectory vectorz)
HyperMesh HMASCII Command
id
The ID of the load (must be unique).
type
The load type.
locationid
The node or element ID where the load is applied.
inputsystemid
The reference coordinate system of the load (must be a valid system or 0).
face
The face where the face pressure is applied.
magnitude
The magnitude of the pressure applied.
pressuretype
0, for pressure; 1, for traction pressure.
vectorx
The x component of the unit force vector.
vectory
The y component of the unit force vector.
vectorz
The z component of the unit force vector
None.
