*encryptions()
Creates a encryption in HMASCII format.
*encryptions (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the encryption.
name
The name of the encryption.
color
The color of the encryption. Valid values are 1-64.
To create a encryption with ID 100, name "my-entity", and color 1:
*encryptions(100,"my-entity",1)
Incorrect usage results in an import error.
