*membersegments()
Creates a membersegment in HMASCII format.
*membersegments (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the membersegment.
name
The name of the membersegment.
color
The color of the membersegment. Valid values are 1-64.
To create a membersegment with ID 100, name "my-entity", and color 1:
*membersegments(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
