*parameters()
Creates a parameter in HMASCII format.
*parameters (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the parameter.
name
The name of the parameter.
color
The color of the parameter. Valid values are 1-64.
To create a parameter with ID 100, name "my-entity", and color 1:
*parameters(100,"my-entity",1)
Incorrect usage results in an import error.
