*metadata_integer()
Creates integer metadata in HMASCII format.
*metadata_integer (entity_type,entity_id,"name",value)
HyperMesh HMASCII Command
entity_type
An integer indicating the type of entity the metadata is attached to. A value of undef indicates attachment to the database itself.
entity_id
The ID of the entity the metadata is attached to. Ignored if entity_type is undef.
name
The name by which the metadata will be referenced.
value
The integer value assigned to the metadata.
To create integer metadata attached to element ID 100, with name "my-integer" and the value 345:
*metadata_integer(2,100,"my-integer",345)
Incorrect usage results in an import error.
