*configurations()
Creates a configuration in HMASCII format.
*configurations (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the configuration.
name
The name of the configuration.
color
The color of the configuration. Valid values are 1-64.
To create a configuration with ID 100, name "my-entity", and color 1:
*configurations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0.120
