*frictions()
Creates a friction in HMASCII format.
*frictions (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the friction.
name
The name of the friction.
color
The color of the friction. Valid values are 1-64.
To create a friction with ID 100, name "my-entity", and color 1:
*frictions(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
