*rigidbodies()
Creates a rigidbody in HMASCII format.
*rigidbodies (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the rigidbody.
name
The name of the rigidbody.
color
The color of the rigidbody. Valid values are 1-64.
To create a rigidbody with ID 100, name "my-entity", and color 1:
*rigidbodies(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2017.2
