*attachmentcontrols()
Creates an attachmentcontrol in HMASCII format.
*attachmentcontrols (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the attachmentcontrol.
name
The name of the attachmentcontrol.
color
The color of the attachmentcontrol. Valid values are 1-64.
To create an attachmentcontrol with ID 100, name "my-entity", and color 1:
*attachmentcontrols(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
