*solversettings()
Creates a solversetting in HMASCII format.
*solversettings (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the solversetting.
name
The name of the solversetting.
color
The color of the solversetting. Valid values are 1-64.
To create a solversetting with ID 100, name "my-entity", and color 1:
*solversettings(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
