*block()
*block (id name color mini maxi minj maxj mink maxk divi divj divk )
HyperMesh HMASCII Command
id
The ID of the block (must be unique).
name
The name of the block.
color
The color of the block. Refer to the color variable chart.
mini
The minimum i coordinate of the block’s corners.
maxi
The maximum i coordinate of the block’s corners.
minj
The minimum j coordinate of the block’s corners.
maxj
The maximum j coordinate of the block’s corners.
mink
The minimum k coordinate of the block’s corners.
maxk
The maximum k coordinate of the block’s corners.
divi
The number of grid lines in the i direction.
divj
The number of grid lines in the j direction.
divk
The number of grid lines in the k direction.
None.
