*frequencysets()
Creates a frequencyset in HMASCII format.
*frequencysets (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the frequencyset.
name
The name of the frequencyset.
color
The color of the frequencyset. Valid values are 1-64.
To create a frequencyset with ID 100, name "my-entity", and color 1:
*frequencysets(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
