*mass()
Creates a mass element in HMASCII format.
*mass (id,type,node1,propertyid,systemid,mass)
HyperMesh HMASCII Command
This must follow *component(). The element will be assigned to the most recent component created using *component().
Nodes must also be defined using *node() before creating an element using those nodes.
id
The ID of the element.
type
The solver specific element type.
node1
The ID of the first node.
propertyid
The ID of the property directly assigned to the element. If specified as 0, the property is taken from the component.
systemid
The ID of the system assigned to the element. If specified as 0, there is no assigned system.
mass
The mass of the element.
To create a mass element with ID 100, solver type 1, node 1, direct property ID 5, no system and a mass of 0.5:
*mass(100,1,1,2,5,0,0.5)
Incorrect usage results in an import error.
