*seamexcitations()
Creates a seamexcitation in HMASCII format.
*seamexcitations (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the seamexcitation.
name
The name of the seamexcitation.
color
The color of the seamexcitation. Valid values are 1-64.
To create a seamexcitation with ID 100, name "my-entity", and color 1:
*seamexcitations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
