*analysis()
Creates an analysis in HMASCII format.
*analysis (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the analysis.
name
The name of the analysis.
color
The color of the analysis. Valid values are 1-64.
To create an analysis with ID 100, name "my-entity", and color 1:
*analysis(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
