*freebodysections()
Creates a freebodysection in HMASCII format.
*freebodysections (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the freebodysection.
name
The name of the freebodysection.
color
The color of the freebodysection. Valid values are 1-64.
To create a freebodysection with ID 100, name "my-entity", and color 1:
*freebodysections(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019.1
