*ice()
Creates an IC element in HMASCII format.
*ice (id,type,independentnodesmax,dependentnodesmax)
HyperMesh HMASCII Command
This must follow *component(). The element will be assigned to the most recent component created using *component().
*icelink must be used to define the independent nodes.
id
The ID of the element.
type
The solver specific element type.
independentnodesmax
The number of independent nodes.
dependentnodesmax
The number of dependent nodes.
To create an IC element with ID 500, independent nodes 100 and 101, node 100 dependent nodes 200 and 300 with DOF 12, and node 101 dependent nodes 201 and 301 with DOF 123:
*ice(500,0,2,4)
*icelink(100,2,200,12,300,12)
*icelink(101,2,201,123,301,123)
Incorrect usage results in an import error.
Version History
14.0
