*timestepcontrols()
Creates a timestepcontrol in HMASCII format.
*timestepcontrols (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the timestepcontrol.
name
The name of the timestepcontrol.
color
The color of the timestepcontrol. Valid values are 1-64.
To create a timestepcontrol with ID 100, name "my-entity", and color 1:
*timestepcontrols(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021
