*group()
*group (id, name, type, config, material_id, color, main_definition, secondary_definition)
HyperMesh HMASCII Command
id
The ID of the group (must be unique).
type
The type of the group.
name
The name of the group.
config
The configuration of the group.
material_id
The ID of the group’s material (must be a valid material).
color
The color of the group. Refer to the color variable chart.
main_definition
Describes how the main entities are defined. Use:
  • 0 - entities
  • 1 - components
  • 2 - box
  • 3 - all
  • 4 - sets
  • 5 - contactsurfs
Describes how the secondary entities are defined. Use:
  • 0 - entities
  • 1 - components
  • 2 - box
  • 3 - all
  • 4 - sets
  • 5 - contactsurfs
Groups collect main and secondary elements only. Main and secondary elements must exist in a group, so their definitions must follow a group definition.
None.
