*modelcheckcorrections()
Creates a model check correction in HMASCII format.
*modelcheckcorrections (id, name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the model check correction.
name
The name of the model check correction.
color
The color of the model check correction. Valid values are 1-64.
To create a model check corrections with ID 100, name "my-entity", and color 1:
*modelcheckcorrections(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
