*physicalquantities()
Creates a physicalquantity in HMASCII format.
*physicalquantities (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the physicalquantity.
name
The name of the physicalquantity.
color
The color of the physicalquantity. Valid values are 1-64.
To create a physicalquantity with ID 100, name "my-entity", and color 1:
*physicalquantities(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021
