*contactgroups()
Creates a contactgroup in HMASCII format.
*contactgroups (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the contactgroup.
name
The name of the contactgroup.
color
The color of the contactgroup. Valid values are 1-64.
To create a contactgroup with ID 100, name "my-entity", and color 1:
*contactgroups(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2017.1
