*bodies()
Creates a body in HMASCII format.
*bodies (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the body.
name
The name of the body.
color
The color of the body. Valid values are 1-64.
To create a body with ID 100, name "my-entity", and color 1:
*bodies(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0.120
