*results()
Creates a result in HMASCII format.
*results (id,"name")
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the result.
name
The name of the result.
To create a result with ID 100 and name "my-entity":
*results(100,"my-entity")
Incorrect usage results in an import error.
Version History
2019
