*node()
*node (id x y z superid inputsystemid outputsystemid surfaceid surfaceindex)
HyperMesh HMASCII Command
id
The ID of the node (must be unique among all nodes).
x
The x coordinate in the local system.
y
The y coordinate in the local system.
z
The z coordinate in the local system.
superid
The super-element ID of the node.
inputsystemid
The input system for the node (must be an existing system or 0).
outputsystemid
The output system for the node (must be an existing system or 0).
surfaceid
The ID of the surface to which the node is associated.
surfaceindex
The fragment of the surface to which the node is associated.
Nodes must be defined before elements.
None.
