*freebodygroups()
Creates a freebodygroup in HMASCII format.
*freebodygroups (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the freebodygroup.
name
The name of the freebodygroup.
color
The color of the freebodygroup. Valid values are 1-64.
To create a freebodygroup with ID 100, name "my-entity", and color 1:
*freebodygroups(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019.1
