*accelerometers()
Creates an accelerometer in HMASCII format.
*accelerometers (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the accelerometer.
name
The name of the accelerometer.
color
The color of the accelerometer. Valid values are 1-64.
To create a accelerometer with ID 100, name "my-entity", and color 1:
*accelerometers(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0.130
