*clearances()
Creates a clearance in HMASCII format.
*clearances (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the clearance.
name
The name of the clearance.
color
The color of the clearance. Valid values are 1-64.
To create a clearance with ID 100, name "my-entity", and color 1:
*clearances(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
