*interfacecomponents()
Creates an interfacecomponent in HMASCII format.
*interfacecomponents (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the interfacecomponent.
name
The name of the interfacecomponent.
color
The color of the interfacecomponent. Valid values are 1-64.
To create an interfacecomponent with ID 100, name "my-entity", and color 1:
*interfacecomponents(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
