*joint_planar()
*joint_planar (id type node1 node2 node3 node4 propertyid orientation systemid1 systemid2)
HyperMesh HMASCII Command
id
ID of the element.
type
Type of the element.
node[1,2,3,4]
The node IDs of the element.
propertyid
The ID of the element’s property.
orientation
The orientation associated with the element. Use:
0
None
1
Systems
systemid[1,2]
The system IDs associated with the element.
This command must follow a *component() command.
None.
