*crosssections()
Creates a crosssection in HMASCII format.
*crosssections (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the crosssection.
name
The name of the crosssection.
color
The color of the crosssection. Valid values are 1-64.
To create a crosssection with ID 100, name "my-entity", and color 1:
*crosssections(100,"my-entity",1)
Incorrect usage results in an import error.
