*independentcoeffs()
*independentcoeffs (coeff1 coeff2 coeff3 etc.)
HyperMesh HMASCII Command
coeff[1 to n]
The coefficient of the corresponding independent node.
This command must follow a *rbe() definition. There must be as many coeffs defined as stated in the *rbe3() command.
None.
