*interfacelinkings()
Creates an interfacelinking in HMASCII format.
*interfacelinkings (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the interfacelinking.
name
The name of the interfacelinking.
color
The color of the interfacelinking. Valid values are 1-64.
To create an interfacelinking with ID 100, name "my-entity", and color 1:
*interfacelinkings(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
